Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
CANNOT COPY, PASTE ALIGNED, MIRROR ELEMENTS IN REVIT 2020 NOR DUPLICATE VIEWS
12 REPLIES 12
Message 1 of 13
1675 Views, 12 Replies
I need help with this error I have been getting after I try to copy and paste aligned, or mirror elements or duplicate views. I have uninstalled and installed Revit 2020 several times already. "A SERIOUS ERROR HAS OCCURRED. THE CURRENT ACTION HAS BEEN CANCELLED. IT IS STRONGLY RECOMMENDED THAT YOU SAVE YOUR WORK IN A NEW FILE BEFORE CONTINUING".  Any help will be greatly appreciated.
G
12 REPLIES 12
Message 2 of 13
bvillarreal-datumsa
Maybe a corrupt install of the coding program it uses.
Reinstall of all windows updates, and the C++ packages.
Message 3 of 13
in reply to: bvillarreal-datumsa
OK will do and let you know. Thanks
G
Message 4 of 13
Message 5 of 13
Benard:
I did but still no change. When I click on the Managed tab and click on steel connections under structural settings I get the "Serious Error ...." message
G
Message 6 of 13
Yes see attached.
Message 7 of 13
Yes i did.
Message 8 of 13
CADmonkey_UK_Building_Services
Is this a problem with any view or elements, or is there one specific group of elements you are trying to manipulate?
You may have a corrupt Family somewhere.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
Message 9 of 13
It is with any view
Message 10 of 13
What about if any Links or Imported Categories are turned off?
Does this happen if you start with a new project and an OOTB Template?
Do you have any obsolete/out-of-date apps or plugins?
Have you tried enabling or disabling Hardware Acceleration?
Are there any Revit, Video Card or Windows updates/hotfixes available?
Message 11 of 13
Thanks for getting back to me. Here are my responses:
Message 12 of 13
Bad luck. My advice is to stop guessing and raise a support ticket with Autodesk. If not you, then someone in your organisation has an Autodesk Subscription.
Message 13 of 13
faisalkhttk88
HI! I am getting the same issue. Can you please guide me how you solved the problem?
