& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I need help with this error I have been getting after I try to copy and paste aligned, or mirror elements or duplicate views. I have uninstalled and installed Revit 2020 several times already. "A SERIOUS ERROR HAS OCCURRED. THE CURRENT ACTION HAS BEEN CANCELLED. IT IS STRONGLY RECOMMENDED THAT YOU SAVE YOUR WORK IN A NEW FILE BEFORE CONTINUING". Any help will be greatly appreciated.
G
Maybe a corrupt install of the coding program it uses.
Reinstall of all windows updates, and the C++ packages.
OK will do and let you know. Thanks
G
Benard:
I did but still no change. When I click on the Managed tab and click on steel connections under structural settings I get the "Serious Error ...." message
G
Thanks for getting back to me. Here are my responses:
1. What about if any Links or Imported Categories are turned off? - Same issue with projects with no links or imported categories
Does this happen if you start with a new project and an OOTB Template? Tried it but same issue.
Do you have any obsolete/out-of-date apps or plugins? Same issue with complete uninstall and Reinstall
Have you tried enabling or disabling Hardware Acceleration? Yes but same issue
Are there any Revit, Video Card or Windows updates/hotfixes available? No or Not that I know of.
If I click on Manage tab and click on connection settings I get the same serious error message. I am using a new 16GB RAM Surfacebook2 with Windows Pro. On my surface Pro3 The same product and everything but I don't have this issue. I noticed that the difference between my surface pro 3 and Surfacebook 2 is that The surface pro has the .NET FRAMEWORK VERSION 4.7 while my surfacebook 2 has the latest .NET FRAMEWORK 4.8. I dont know if that's the problem. If I check the Journal Worker Log it says there was a "System Type Initialization Error"
G
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
