I've wasted all morning fighting Revit or looking online for solutions to a simple task. I simply need to run a railing along a sloping beam that I'm using as a stair stringer. I've finally gotten a guardrail modeled along the the 2 slopes of the stringers and the flat section at the intermediate landing, but it took manually adjusting the slope and the stair path projection line lengths an inch at a time about 20 times to get it all adjusted to (more or less) line up with the beam stringer. Of course, none of that manual setting will adjust if the stair changes slightly. But is there no way to host a railing to a framing member??? This seems so incredibly basic, especially since Revit has stair and railing "connections" that only work with framing members and not the stair or railing tools. This is crazy that that Revit can't do this simple step.
