Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Brick wall tab and material missing
1 REPLY 1
186 Views, 1 Reply
Dear Sir
I want to model common brick wall. but brick wall and material tab was not found. may be purge or something.
when other Revit model insert common brick wall that also can not merge (material or content) in the model.
Please see the attachments.
1 REPLY 1
ennujozlagam
check if you are using correct templates or download and install revit content here and see if helps. thanks
Forma Design Contest
Technology Administrators
