BOQ, Scheduling, detail drawing in Revit Structure.
rudra5FZN6
rudra5FZN6
I need assistance with Revit Structure to create a bar bending schedule and material takeoff for the structural components in my model. Could you please guide me on how to generate accurate schedules in a professional manner?
jay_colcombe
If you are using the Structural Template there is already a Bar Bending Schedule in the Template so you can use this all you need to really do to get it working correctly is add the Rebar Number and Remove Bar Mark.
This is a great starting point and then add any additional Parameters as required.
As regards other Schedules, please use the Help Guide/YouTube/etc.
There is a good Autodesk Learn Platform which will get you most of the way and then use the forums for more in-depth help/support when you get stuck.
Autodesk Learning
On-demand Learning | Autodesk
For example - Create Rebar bending schedules in Revit | Autodesk
One final Tip, if you purchase your Autodesk software through a reseller use them as a primary source for training and additional help and training if they want your business i am sure they would be happy to help!
Jay Colcombe
Autodesk Certified Instructor
rudra5FZN6
Thank you for your response. However, I also need information on the overlapping distance and bar placement. Do you have any insights on this? Additionally, is there a way to place rebars in a single step, rather than having to place them separately in each component every time?
jay_colcombe
It depends on what you are trying to do, I have no idea but you can propagate Rebar
You can use the Propagate Rebar Tools and Align by Face and Copy to other elements
Help | Propagate Rebar | Autodesk
Jay Colcombe
jay_colcombe
For overlapping distance and Bar Placement you need to use Constraints - again this is all in the Help in Revit
Help | About Rebar Constraint Types | Autodesk
Alternatively there are addins to Revit for Rebar which do all these things you ask and if this is your primary task and main focus in Revit you really need to look into these to allow you to cover the missing elements.  This is one i have used personally.
CADS RC3D - Detailing in Revit taken to the next level - CADS Software
RebarCAD 3D for Revit - Rebarcad
Jay Colcombe
