Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Bolting Column to Beam Connections
2 REPLIES 2
stherrienWNCR4
193 Views, 2 Replies
I have a structure made with w-shapes. I was able to place the column base plate and cap plate using the Revit "Connection" command. However, I could not find a suitable "Connection" to weld a plate welded to the underside of the w-shape beam. Instead I modeled a component in-place but I am now not able to bolt the beam plate to the column cap plate. Can anyone help me with this?
2 REPLIES 2
awes
in reply to: stherrienWNCR4
In that case you can use Steel/Fabrication Element/Plate
stherrienWNCR4
in reply to: awes
This seems to resolve the issue. Thank you!
