Bending rebar sketch
semi
Message 1 of 11
semi
Hi everyone,
does anyone know why Revit does this?:
Mirroring or changing the parameters also isn't an option as the shape gets mirrored as well + it would even be a bad workflow to model the rebars and then mirror everything.
It's always something...sigh...
Replies (10)
Message 2 of 11
jay_colc
Not 100% if I am on Page here, but place using Space so it was on the Left (as I know it needs to be flipped)
Then changed the Angle to 180 degrees
it would be nice to have Flip Controls in the Label directly - Annoys be when placing a Realistic which is oriented correctly and then switching to Schematic if flips around!
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 11
semi
This seems to workn but then I need to switch my entire detail to the left side:
Message 4 of 11
semi
btw: also take a look at shape 51: it's flat
My engineering company won't like this.
I was super excited to finally get to use the bending details, but it turns out to be a major disappointment
Message 5 of 11
jay_colc
This is what I see for Shape Code 51?
Jay Colcombe
Message 6 of 11
semi
Sorry if not being so clear.
Message 7 of 11
jay_colc
If you asking why it does not automatically come in a Vertically alignment automatically for Schematic Detail I can only assume there is something in the background driving this?
As Orientation > Model should do this but by providing the other Orientation and Rotation Settings you can achieve the result you need but not automatically so maybe something you can raise with the developers.
Jay Colcombe
Message 8 of 11
jay_colc
FYI @semi
Structural rebar bending detail flipped in Revit (autodesk.com)
Jay Colcombe
Message 9 of 11
semi
Thx for the info, guess we'll go back to our own self made sketches then 😞
Message 10 of 11
jay_colc
To be honest if I was doing Rebar day-in day-out I would be using Graitec or CADS addins for speed and functionality as Revit is always playing catch-up in this area!
Jay Colcombe
Message 11 of 11
semi
my client only wanted to invest in AGACAD
