Beams auto deformed when placed in certain areas
hey, so I just want to make a good old standard beams, but when placed in this area, the beams seems to be deformed like the picture which i have attached in this post (highlighted in blue), it didnt look like that if the beam was placed anywhere else, any idea why?
ennujozlagam
you have to drag to blue circle to the edge? thanks
tried that, it didnt work tho, thank you for answering
ennujozlagam
post some part of it here so we can check? thanks
ahjorn
You may have to change the join order with whatever is intersecting the beam causing the weird cut-out shapes in the beam
