Concrete render in 2021
RobDBrown
Message 1 of 11
RobDBrown
The render appearance of Concrete has changed in a 3D realistic view from 2019 to 2021 although the material properties seem to be the same ?
This colour change make the contrast between vertical and horizontal edge difficult to see.
Could this be another setting ?
Replies (10)
Message 2 of 11
ennujozlagam
it could be different setting? try to change the materials of concrete to current revit 2021 and see if helps. thanks
Message 3 of 11
RobDBrown
All the settings are identical to 2019 but the look of concrete still different in Realsitic view in 2021
Message 4 of 11
ennujozlagam
can share the file so we can check? thanks
Message 5 of 11
RobDBrown
would rather not share the file but if you draw a slab in 2020 then in 2021 can you see a difference in realistic 3d view ??
Message 6 of 11
ennujozlagam
just copy a part of it not the whole project and paste into a new file? and share here? thanks
Message 7 of 11
RobDBrown
It's something to do with the sun i think because as i turn the 3d view the colour changes especially when it's upside down
Message 8 of 11
RobDBrown
see attached
Message 9 of 11
RobDBrown
see attached views from different angles where rendered concrete
colour is different
Message 10 of 11
ennujozlagam
dude, i need the file (rvt) just part of it not the whole projects. i can't do anything in a jpg file file by looking at it. thanks
Message 11 of 11
RobDBrown
i've just found a post describing the issue so thanks;
Realistic Views: Option to turn off sunlight tint.
In realistic views in Revit 2021 the sunlight color is tinted to simulate atmospheric scattering which can result in a slightly yellow tint to renderings. It would be very useful to have the option to omit this tint.
