Graphical schedule of concrete columns
ArmanMargaryan
ArmanMargaryan
Hello everyone,
Are there people who have experience in creating graphical schedule of concrete columns? I need to get it in Revit, as it is in AutoCAD (See picture).
PS Data is transferred from Excel. I tried to create Shared Parameters to download data via Dynamo.
Is there another solution?
Thank you.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
@ArmanMargaryan Shared parameters for deal load, live load, size/number of vertical bars need to be created in the column family.  That is where the data will need to exist.  Next, create column tags to display the new shared parameters as shown in your screenshot.  Dynamo can help with populating the parameters, but the tags may have to be manually placed on the graphical column schedule view in Revit.
ArmanMargaryan
Thank you for your answer.
Unfortunately, the graphical column schedule does not allow us to do much, is it more appropriate to use Macro Manager?
Arman Margaryan
Linkedin | Facebook
WEC17
All you need to do is add share parameter to Structural Column Tag, once you are done do the same thing to your Column family and you will be al set.  Also you have create a template and manipulate the look of the schedule. I change the Columns line to be white that way I done see the columns and just the Information need it.  Let me know if you have question. I send you the Structural Columns Tag.
Here is a pic of my Graphical Column Schedule.
