Beam Tag elevation height
dhakshanamurthy.sriraman
Hi All,
When i use Beam tag in Revit, the  tag shows the elevation from Project base point instead of Survey point.
Tried searching option but there is none of the option for changing the eleation types like elevation tags.
Please help is there any other way to show the beam height from survey point in tag.
See attached image (My project base point is 0 and survey point is +100).I need 100 is my level in beam tag
alan.johnson7YLND
I guess you will just have to indicate the elevation separately with the spot elevation set to Survey Point
Hahaha,.Yesss...i gave this to team, But they have 100's of beams to be tagged,..I think it's time to learn Dynamo in deep...
