Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Beam Connection issue
5 REPLIES 5
655 Views, 5 Replies
Hello guys, i'm trying to connectu a structural column with beam, it seems pretty easy but i've got always this issues :
-Connection failed
-Invalid type or number of input elements
 both together ...
I've seen some similare issue on the forum but it still not working... can someone help me please?
I attach the project below. Thank you ahead
5 REPLIES 5
JuanYusta
Hi @zifo.ar
What connector are you using? I have deleted your connections and I have done it again, I have not had problems.
In the following video I show you how to do it:
in reply to: JuanYusta
hello, thank you for answering me,
I tryied and it still do not work, but using another computer it does.... i think I have to reinstall Revit again or if i can ask, there is a way to just fix it without uninstallation?
ArmanMargaryan
I tried, I also succeeded, you have to install Revit again.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
ArmanMargaryan
If the issue is resolved, please confirm.
Arman Margaryan
Linkedin | Facebook
Jamhmer_Oc
Hi @Anonymous
You can repair it. Always take the last option to uninstall and install it again, as it causes errors.
https://knowledge.autodesk.com/es/search-result/caas/sfdcarticles/sfdcarticles/ESP/How-to-reinstall-or-repair-your-Autodesk-product.html
Jamhmer Oc
