Hello guys, i'm trying to connectu a structural column with beam, it seems pretty easy but i've got always this issues :
-Connection failed
-Invalid type or number of input elements
both together ...
I've seen some similare issue on the forum but it still not working... can someone help me please?
I attach the project below. Thank you ahead
Solved by ArmanMargaryan. Go to Solution.
hello, thank you for answering me,
I tryied and it still do not work, but using another computer it does.... i think I have to reinstall Revit again or if i can ask, there is a way to just fix it without uninstallation?
I tried, I also succeeded, you have to install Revit again.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
If the issue is resolved, please confirm.
Arman Margaryan
Hi @Anonymous
You can repair it. Always take the last option to uninstall and install it again, as it causes errors.
Jamhmer Oc
