Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Attach the bases of structural columns to isolated foundations
2 REPLIES 2
reza_naserit8
173 Views, 2 Replies
Why When attaching the bases of structural columns to isolated foundations, the columns attach to the topmost surface of the foundation where the geometry of each element meets 🤔 ???
for example I want the  steel column extends ( 3 ft ) to the footing like pictures but impossible
2 REPLIES 2
anze.kumar
in reply to: reza_naserit8
Is it necessary to have a column attached?
YOu could just 1) attch it to the Footing
2) Detach it (so you have an exact base of the top of the surface
3) Adjust Base Offset to be -3ft below the top most surface of the foundation
3a) You can also use the option "Offset From Attachment"
You could also - simply Lock the Foundation to a Level using Align & Lock and then Edit the Column Base Offset
"An attached structural foundation will be moved to the bottom of the column" when adjusting column ...
Jay Colcombe
Autodesk Certified Instructor
Forma Design Contest
Technology Administrators
