Area Reinforcement is sketched completely outside of its host.
KateMorricalTowne
Message 1 of 8
KateMorricalTowne
Anybody know what triggers this alert? I have some area rebar in a wall that appears to be clearly INSIDE its host, yet the message still shows up. Cover displays properly in section.
Kate Morrical
Digital Design Manager, Washington DC
BIMmuse.com
Replies (7)
Message 2 of 8
Max.Kotsar
Hi, Kate!
Can you upload your file or couple screenshots with alert?
Max Kotsar
Сообщение полезно - Проблема решена -
Message 3 of 8
KateMorricalTowne
Here's a sample. The extents of the wall width are where the blue dots are for the reinforcement; its height extends both above and below the area sketch.
Kate Morrical
BIMmuse.com
Message 4 of 8
KateMorricalTowne
Posting the image as an attachment in case you can't read the inline version...
Kate Morrical
BIMmuse.com
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Could you be so kind and send us or attach to post example revit file?
Rafal Gaweda
Message 6 of 8
This case is solved or close? I have teh same problem!
Message 7 of 8
jachyme
Hi, to be able to help you we need an example file just with this case if it is possible to extract it from the entire model.
Thank you
Ewa Jachym
Principal User Experience Designer
Message 8 of 8
I solved, editing the shape. Ty
