Area reinforcement host.
JBelinski
JBelinski
I think it would be a great idea to be able to select an existing floor or wall to be the host of area reinforcement.  I don't understand why the area reinforcement has to have a separate boundary.  I already created the boundary when I created the floor or wall element.  If the floor or wall changes shape, the area reinforcement boundary would change too.
JBelinski
Do others not find this idea useful, or is there a better option that I am unaware of?
ovidiu_paunescu
Hi @JBelinski
You can do that using the following steps:
  • launching the command for area reinforcement
  • selecting the host (wall or floor)
  • In the ribbon, select the major direction and draw one line (maybe along one edge)
  • Click finish
The result is an area reinforcement completely defined by the contour of the element, including openings
Here's a simple example
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
JBelinski
Thanks @ovidiu_paunescu.  I had no idea that I didn't have to recreate the boundary.  I was using the rebar line tool to sketch the outline.  I tried your description, and it worked great.  Thanks.
