Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Switch Join Order problem
I have changed the join order of beam and slab in order to cut the slab. Even after changing the join order I can't find beam cutting the slab.
aadityangokul
Hello!! @Anonymous
--->In 2D give join geometry and select the slab and beam. IF IT NOT WORKS, go to 3D view of the particular beam and slab(section box- BX) and give join geometry in 3D view by selecting those elements.
Aadityan Gokulakrishnan
if your trying to get those all to join as one make sure
The material is exactly the same (cast in place concrete) & ( concrete ) are not the same
the patterns look good just make sure u don't have the same pattern in two different types
