apply "Revisions on sheet" to multiple sheets
Message 1 of 9
Is there any way to apply a revision to multiple sheets throught he "Revisions on sheet" button in the properties?
Replies (8)
Message 2 of 9
L.Maas
No.
That is one of the reasons I created an entry in Revit Ideas.There are several/many areas in Revit were mulitple selection is not implemented
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 9
you can use API .
I believe KIWICODE bonus tool can solve your problem.
Message 4 of 9
In addition to that, giv a go to freeapp on Autodesk Exchange app,Xrev freebies suite
Message 5 of 9
BradOatOlsenPerformance
What I do is draw a tiny little revision cloud in an inconspicuous place, on one sheet, copy and paste onto the sheets that need rev'd up.
Bradley Olsen, P.E.
Intel i9-9900K (8 cores O.C. to 5.3 GHz)
32 GB Ram
(2) Quadro P4000 in SLI
Message 6 of 9
Not natively in revit, no.
There is an app called Xrev Freebies, that will do this for you. I've linked it down below.
Xrev Freebies Link
Message 7 of 9
I use Xrev Freebies as well.  Works great.
From Revit 2018 you can do it natively though.  Expand the entire Sheet tree, highlight all Sheets including the views inside the Sheet tree, then you can Edit Revisions on Sheet once for all of them.
Message 8 of 9
brett_73
thanks for the link to xrev freebies .
I'm using revit 2020 and this add in works perfectly for adding individual revisions to multiple sheets at the same time.
Message 9 of 9
z.bookwala
Community Visitor
Community Visitor
Selecting multiple sheets though, removes the 'Revisions on Sheet' parameter though from the Properties Window
