Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
analytical model not found
6 REPLIES 6
alikdi26
4134 Views, 6 Replies
i cant see any analytical plan/view in my rvt 2020 version i enabled in vg options and i tried to make it by duplicating view but when applying template settings there is also no option to select structural
i tried it in structural template in the photo there is only floor plan
i cant see analytical model in view templates too
[screenshot attached]
Tags (1)
6 REPLIES 6
Jason.P
in reply to: alikdi26
Have you tried, when you go in to your View Template, edit v/g overrides analytical then in your V/G settings under Analytical Model Categories, make sure the Show analytical model categories in this view is checked. That would be my first suggestion. let me know how it goes.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
alikdi26
in reply to: Jason.P
 first f all im am a student and very thankful to your responds
sir, here first prt scr that is selected structural temp
and i got the discipline as arch. or coordinates never got structural discipline. its always like that when opening struct temp
as u said i did your suggestions already. i ticked ok in vg [ analytcl tool opt]
& i tried to make a duplicate 3d view and renamed as analytical view then i unchecked all other opt in vg except analytical opt i got some thin layer over my slab and colums,bm,walls...
but the exact analysis visual is not able to see as in the tutorials like the separated  diffrent colors {sky blue ,brown , idk how can i mention here}
everybody replying that analytical view is automatically generating stuff
but in mine its not like that
only visble the levels like
level 1
lvel2
level 3.....
what i want is
level 1
level 1 -analytical
level 2
level2 - analytical
i tried my best but failed
im self learning bim
student kindly respond
Jason.P
First thing you will need to do, is uncheck the half tone in your V/G over ride, that will make sure your analytical model stands out better.  then in your Model categories under Structure, check halftone for everything, and that will make your physical modeled elements lighter and turn your transparency down a bit.
Jason Peters
BIM Manager
alikdi26
thanks sir ,i did it .is there any sense for asking your personal contact options for queries and to learn bim options myself in its own right way.
as i told im am civil. engg. grad. im working but learning bim myself .so i have to ask this help for my easy learn
Jason.P
Sure I will send you a message with my email address in it.
Please accept my response as the "accept solution".
Cheers
JP
Jason Peters
BIM Manager
jrobertoavca
Hello Jason! Im using Revit 2023 and im experiencing the same issues, is there any way you could help me out? I cant see any analytical member in the respected 3D view, doesn't matter what overrides I check, the analytical view is empty.
Forma Design Contest
Technology Administrators
