Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Analytical Model Creation Not Working
2 REPLIES 2
tovarog23
244 Views, 2 Replies
I have been struggling with the new automatic analytical model creation tool in the newest Revit version. My project consists of a midrise structure with walls, beams, and slabs mainly and every time I run this "dynamo" tool Revit freezes or takes too long and remains "running".
What can I do?
Labels (1)
2 REPLIES 2
catalin_lang
in reply to: tovarog23
Try to select only a part of the model. Could be an element/group of elements where it stumble.
catalin.lang
lim.wendy
Hi Rogelio,
Thank you for submitting your question in our discussion forums. It looks like Catalin's suggestion to select only a part of the model may work, so for now, I will mark his reply as the "Answer." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Please let us know if you require further assistance.
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
