Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Analytical Curve beams
4 REPLIES 4
Djokaboris
288 Views, 4 Replies
Hi;
When i convert physical to analytical curve beams it doesn't convert as expected. In addition to that, there is no option no modify the wrong analytical  beam convertion like in analytical curve panels.
4 REPLIES 4
msgambelluri
in reply to: Djokaboris
Explain how it does not convert it as expected. What were you expecting?
Marcello Sgambelluri
jay_colcombe
At present it appears this is beyond the scope of the analytical Process and you have to manually create them using them manually
Jay Colcombe
Autodesk Certified Instructor
msgambelluri
OOTB Automation tool does not work correctly as stated. Instead consider using the OOTB dynamo node. Place these nodes instead or similar workflow. It will create the analytical curve that follows the physical beam.
You will need to change some of the analytical instance properties once created but at least it creates it.
Djokaboris
in reply to: msgambelluri
😂😂To follow the physical curve beam path. The great Mr Marcello,  honored for your message reply. Still a novice in  coding especially dynamo, so please bear with my question for now😅.
Forma Design Contest
Technology Administrators
