Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
analytic Panel by extrusion
3 REPLIES 3
Djokaboris
135 Views, 3 Replies
Hi;
When i create the panel by extrusion and pick a physical curve wall, the analytic panel by extrusion appears below the physical wall. And when i move it back up, it doesn't go to the required position. How can this be solve??
3 REPLIES 3
jay_colcombe
in reply to: Djokaboris
It is related to the Workplane, in 3D your Workplane is probably set to a lower level at the bottom of the Wall, change it to the top and it works as expected.  This could be a Structural thing whereby it works downwards like when placing columns.
Jay Colcombe
Autodesk Certified Instructor
mihai.sandu
The position of the analytical elements and their size can also be controlled from the Analytical Nodes. Enable the Analytical Nodes in the view, select the 2 top Nodes of the curved analytical panel and in the Properties menu you will have Associated Level and Offset from Level. You can control the size from there, by changing the values.
Mihai Sandu
Sr. QA Analyst
Djokaboris
in reply to: mihai.sandu
Thanks Sir @mihai.sandu . It works perfectly
Forma Design Contest
Technology Administrators
