Aligning ICF Wall Components
Seeking an easier method to align ICF Wall Components.  The first row is easy, but the second is more difficult since they need to stack vertically and align horizontally.  Clearly, I am a beginner and have searched for the solution prior to asking this forum but would appreciate your expertise.  Here is an example of the component downloaded from Nudura.com.
Thanks!
Judy_S
Hi, stephen.hebert.dbs,
I see you have a question about using Nudura ICF wall components in Revit and I'll be happy to try to answer your question. It sounds like you're trying to build a wall in Revit with these components - is that correct? I'm unfamiliar with these items, but I looked on the Nudura website and found this: "The NUDURA 3D Form Unit Models/Families give the Design Professional the ability to view the geometry of each NUDURA form unit and manipulate the form to achieve any view needed without leaving the comfort of his/her office. Note: Due to file size, these models/families are intended for viewing purposes only and not for assembly within a project." It seems that these components are not intended for use in a Revit model but rather as references. Have you tried contacting Nudura for more information about their BIM library and how best to use it?
Let me know if this helps, or if you have any other questions. Thanks!
Best,
Judy_S
Judy.S
Product Support Specialist, AEC
Link Name | Link Name | Link Name | Link Name
