Revit-Robot Model Results Problems
hazimsal
hazimsal
Hello There
I have been plagued with a few issues this past month with both Revit and Robot 2017. Both hotfixes and updates are up to date, however Robot has been plagued with the crash upon startup issue and the second problem is
When I use another workstation to transfer my Robot Results package to Revit for coordination purposes, I get an error saying that "An identical Key has been added" and the Results Explorer will now state that "No results are available" despite having the Results Package perfectly (error free) transferred back to Revit.
Please help - these frustrating issues are debilitating and didn't occur a month or two ago
hazimsal
Forgot to add: This issue is the same whether I send the entire model or selected portions of the model
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @hazimsal
Try not to import reinforcement.
If it is not the case please post Revit file and calculated Robot file.
Rafal Gaweda
hazimsal
No, the reinforcement packet wasn’t transferred to avoid errors. Just the results package for simple load combos. Uploading file shortly
hazimsal
@Rafal.Gaweda Files uploaded
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @hazimsal
Solved in https://forums.autodesk.com/t5/robot-structural-analysis-forum/revit-robot-model-results-problems/td...
Please do not post the same issue in many locations as it makes following the topic development very difficult and makes forum users spent time on already resolved one. Thank you.
Artur Kosakowski
