Hi
Ive picked up that as per screenshots attached, elements from Advance steel that has the mirror tick in positioning goes thought to Revit fine in 2018. But in 2019, it inverts the beam when it goes into Revit?
This causes big problems, especially if you use macros that does this automatically like stairs ect. So it can cause you to spend a lot of time to correct it afterwards in Revit
Any ideas?
2018 Stringers is fine
2019 One stringer is mirrored
