Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Add extension to railing end
1 REPLY 1
ChrisGamble
452 Views, 1 Reply
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revi... this link explains how to do it but when you open the type properties for railing, there is no "extension" parameter. Can someone explain this?
1 REPLY 1
in reply to: ChrisGamble
You can edit the Handrail type via the Family Type browser or TAB select it in the model.
Forma Design Contest
