about loosing rebar constraints
hi everyone
i have been trying to create the curved rebar by the free form pattern
and the problem is after saving the file, i reopen the file and the rebar constraint is lost
so not to be lost the constraint,
do i have to lock the rebar?
what is the problem?
why did that error occour?
thank you so much
ovidiu_paunescu
Hi @Anonymous
Can you post a sample project showing this issue?
Free form rebar loses the constraints only if one of the references is deleted or the bar (set) is moved/copied without all the references.
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
