put repeated times the same model view on a sheet
andres_urrutia
andres_urrutia
hi colleages.
I have modeled just one structure but I have to put on a sheet an array of them because there are multiple structures projected.  I don't want to make an array of this estructure because I dont need it. the question is: is there any way to represent an array of a view of the same structure wich is modeled just one time?
vick1z
I'm not sure why would you do Array but to get this done only I can think of you need to duplicate view and place on sheet.
andres_urrutia
yes, I want to represent on a sheet an array like this one.
here are 14 blocks (this is a view plant) but I have modeled just one. the block are set together. I dont know if this is posible..
If I model all the blocks, the size of the file Will increase a lot and I just wan to represent a general plant and elevations with the array.
Create a view showing only that structure then duplicate as dependent multiple times and place them in sheet. Or create Assembly from the structure, generate Assembly views and duplicate similarly to the previous approach.
Btw, are you with Santos Urrutia?
andres_urrutia
I decided to draw the view on autocad and put the view as an imported view on revit.
I dont know Santos Urrutia (I'm from chile)
Jason.P
Have you thought of grouping the framing, and then coping the group as many times as required. Up side is, if you make a change to the group it changes in all of them.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
