I copied the 1st floor of my building onto the second, however, I can't see it on the 2nd-floor plan. Please tell me what im doing wrong
Solved by hmunsell. Go to Solution.
Solved by _Vijay. Go to Solution.
all of your elements are drawn on the Project Completion phase. if you want to see anything you have to set your view phase to the correct phase for the elements drawn on that phase.
you can leave the Phase filter set to Show Previous and New, but the phase needs to be set to Project Completion. or change the phase of the element so show properly with the phases set up in the model.
Howard Munsell
