So i have this simple 2d detail item family for a rebar
When i use this detail item the two families move together the rebar and the annotation tag in the blue circle .. i want to allow the user to move the tag alone and when he moves the detail item the tag moves with it
Solved by hmunsell. Go to Solution.
Are you trying to tag the family after its placed, or it the text part of the family?
Howard Munsell
The annotation tag is another family i created and loaded into the detail item family
So when i load the detail item family in my project its created with the annotation tag
I want to allow the user to move the tag alone without moving the detail item
I don't think you'll be able to do that. Once its in the family, with out adding dimensional parameters, it is where it is placed. Why not just place it as a Tag (Tag All or Tag by Category) and let the user move it as needed?
Howard Munsell
Hi @shehabfikry1996,
Welcome to the Revit Structure forum. Thank you for submitting your question in our discussion forums. It looks like Howard has answered your question:
I will mark his reply as the "Answer." This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Please let us know if you require further assistance.
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu > Not the Solution to cancel an accepted answer.
