- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Attempting to build some things with Revit 2019 Steel menu. Plates were working great until I tried to put a hole or opening in one. I suspect it's not behaving because instead of making the usual 1/2" plate, I sketched the end view of a 3/8" bent plate and made this plate 5'-8" 'thick'. See image. Holes and contour cuts will not work in this bent plate. So, how do I put a 4" square hole in my bent plate? The image shows the cover for the hole. I tried 'model in place' and created an extrusion, but I still can't figure out how to get a hole in it. Creating a void did not work unless I'm doing something wrong with the void command in relation to my extruded bent plate.
Any suggestions? How about suggestions for bent plates in general?
