Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
wires in 3D
2 REPLIES 2
GHASEM_ARIYANI
395 Views, 2 Replies
wires in 3D
hi
Is there any way that we can see the wires in 3D?
I want to calculate the length of wire used in the project،In what way can we do this.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
abulla
in reply to: GHASEM_ARIYANI
Wires are basically annotation objects, so they have no actual geometry to them. If you tab through and select the actual circuit, there is a Length parameter in the properties. I have no idea how Revit calculates that length though.
GHASEM_ARIYANI
in reply to: abulla
Thank you for your answer
But this is not properly calculated.
I assume that I buy the wire required for your project،
With this project, I calculated the risk of falls.
Forma Design Contest
