Why is my reducing tee doesn't change size to match the connect pipe?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
It's me again, I'm a new in the pipe design. I'm trying to create a reducing tee in Revit, but when I insert to the projects, the tee doesn't change the size to match the connect pipe (well, the youtobe tutorial didn't tell me about this reality life ). I don't know how to fix it. Any information would be extremely helpful, thank you in advance.
Attachments are .rfa file and .csv file. Revit version: 2023.
Questions:
1. Below is my family types parameters, I don't have any knowleges about how to set up the formula with: if(), or cos(), sin(), cos()...., that's really complicated to me, so I only use the simply formula and lookup table to set up my parameters, and I'm not sure if it's correct.
2. Below is family types parameters from Revit build-in family, for the tick size, 0.4*..., how this value comes from? In my case, all the tee tick size are different depends OD and ID for each, they all difference, can not use 0.4*sth=my really tee tick size. for example: SS-10S Tee, ND 2", OD 2.375", Wall thickness is 0.109"
SS-10S Tee, ND 3", OD 3.5", Wall thickness is 0.120"
SS-10S Tee, ND 4", OD 4.5", Wall thickness is 0.120"
SS-10S Tee, ND 5", OD 5.563", Wall thickness is 0.134"
These values are completely unrelated and cannot be obtained from another by applying any coeffcient.
And samething as FOD value "1.02", ND+10.6mm, 0.71*ND+33.2mm, etc. How these values comes from?
3. Every time my colleague places a newly created family into a real projects, different problems occur and it doesn't work properly. I'd like to know why. Because I still have many more families to build (elbows, flanges, gasket, butt weld, etc). If I don't know the correct way to create a family and how to use formula properly, it's impossible to build a truly functional family.
Thany you for everyone's help!
