Is there a way to suppress the Desktop Connector 'select projects' dialog popup at login/startup?
abrownPBA
abrownPBA
We're rolling out 16.8 to a large number of staff and I'd like to pre-configure a regedit to suppress this dialog from popping up everytime a user logs on, is there a way to do this?
RSomppi
Have the user selec t a project the first time it comes up. As long as one is selected, it won't prompt for selection.
abrownPBA
This is exactly what I'm trying to avoid. There will be many staff this is rolled out to, many of which need the connector, but not need to engage with it.
RSomppi
Sorry, I misunderstood your question. I thought you were trying to avoid having to do it everytime they log in. Doing it once to avoid having to do it everytime doesn't seem like such a bad thing.
fabiosato
It is very important to select at least once to guarantee access to the proper projects.
Fábio Sato
SebastianGiese
@abrownPBA
Do you have any solution for this problem?
RSomppi
As stated above, you need to select at least one project. If no projects are selected, the prompt will come up. If you don't want to select projects, you don't need the connector,
