Pipe only shown as drop when changing elevations
spitchfordLY3LA
spitchfordLY3LA
Showing pipe in fine detail only shows the change in elevation of the pipe as a drop. I have the Rise/Drop symbols set but the rise symbol only shows when pipe is outside the view range. That's not what I want. I want the rise and drop symbols to show as rise symbol whenever there is an elevation change upward.Revit_Fy4wsFrRD4.pngRevit_52RFwIi1sT.png
RSomppi
What you've posted is how pipe is usually shown at coarse detail. Fine detail is usually for double line pipe. I'm pointing this out because when you look at double line pipe you will always see the elbow in the correct physical down position. That alone should answer your question as to why Revit does it like this but I will explain further.
This is how vertical single line pipe symbols are done in drafting and how Revit does it. It's based on customary drafting standards. A pipe that drops to the floor below or is entirely in the view range will always be a drop symbol. Those symbols do not indicate the direction of flow. I'm assuming that you are basing this logic on the direction of flow because if it were going in the opposite direction the symbology would be reversed and would be hard to understand for anyone familiar with piping drafting. Before you say that this is the way you've always done it in another program and you need Revit to work this way, I suggest that you move over to the Ideas forum and suggest it as a new feature. It probably won't ever happen, though.
You might be able to get what you desire but it would most likely be a manual exercise without any intelligence getting information from the model and it would be prone to errors.
spitchfordLY3LA
I meant to say coarse detail. What I am really trying to do is convince my boss and our field installers to move to Revit. Something like this, while small, can be a deal breaker if I can't make Revit drawings look exactly like our CAD drawings, because yes fire protection drawings are drawn to follow the flow of water.
RSomppi
Your place of work doesn't follow conventional drafting standards. Most of us that have made the transition from other programs have had to make some concessions and changes to workflows in order to take advantage of the benefits of Revit. If this is a stumbling point for your bosses, you may as well stop trying to convince them as there will be more. They have to buy into some wholesale changes or you will be fighting a losing bottle.
