Want the hole area
Want the hole area
pe_simon
Want the hole area
pe_simon
I want the cross section hole area, not the square area without hole, how can do it? Thanks.
I want to make this.
Create one without hole and subtract it to the one with hole then you can have the hole area.
pe_simon
Can you show me in pictures or screen record?? Thanks.
Not sure why pictures are necessary.
- if you are 2022 then associate the void's cut geometry with a y/n instance parameter
- write down the area when the parameter is ticked versus when it is not then do the math
- if you are 2021 or older then just create 2 families, one with the void and one without
pe_simon
OK. Let me try, Thanks.
Or do you want to show the area of the hole as an actual parameter?
pe_simon
Hi, I got it, thanks and how to combine it? When I move its separated.
