Hi all,
I have come to encounter a problem when loading the void extrusion into a family. Firstly, i created a face-based void extrusion as a family for the holes. Then, i have tried to nest the void extrusion family into second family for the wall. For the second family, the wall has a double layer. The first top layer consist of shape similar to pyramid which i created using blend and the bottom layer was created using extrusion. Ofcourse, both layer was joined as a geometry before i load the void extrusion family.
Apparently, the void extrusion was unable to penetrate through the wall. The penetration stops at top layer as shown in the photo below.
Did anyone encounter this similar problem before? Somebody please help
Solved by L.Maas. Go to Solution.
This is the expected behavior. The face based void penetrates the object to which the face belongs.
You would have to repeat the process of placing the face based voids on the second object. You also could create the voids in the hosted family itself (instead of using a nested void family) then you could use a single void to cut multiple objects.
Louis
Please mention Revit version, especially when uploading Revit files.
Hi @L.Maas ,
I follow exactly the steps you told here. It seems one of the holes here did not penetrate, which is quite weird to me.
Does the method that you have suggested here works on parametric array void extrusion? Let say if i want to control the number of void extrusion on the wall etc. Basically, I am trying to perform two-axis void extrusion on the wall here, so i must need a nested family
