why the walls and the doors of architectural link are hidden but when i zoom in or out it appears , as soon as i remove my finger from the scroll of the mouse it disappear again
Its an architectural view, Mechanical, Electrical...? Have you checked the view range?
Can you upload the model to check?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
I am guessing your view setting is set to Hidden Line? IF you switch it to wireframe can you see it now? If so, it means that there is an element in your way blocking it, which would typically mean that your cut plane in your view range needs to be adjusted.
