VERSION OMNICLASS CODES - TABLE 23
I am a italian technical employee and in the last times i use the BIM (Revit Autodesk) for to learn a tool for my job in Italy.
I have seen that the OMNICLASS material codes proposed in the web site  http://seek.autodesk.com/ are different from the last table 23 2012.
It would seem that these codes are referred to version 2006 (OmniClass_23_2006-03-28).
I would understand if :
OmniClass codes _Version year 2012 exceed and eliminate the 2006 version, or if the versions are complementary with each other.
Thank you Smiley Happy
Sono un'impiegata tecnica Italiana e ultimamente uso il BIM (Revit 2017 AUTODESK-versione gratuita di prova) per imparare uno strumento per il mio lavoro.
Ho visto che la codifica dei materiali OMNICLASS proposti nel sito http://seek.autodesk.com/  sono differenti dall'ultima tabella 23 OMNICLASS pubblicata sul sito ufficiale OMNICLASS 2012.
Sembrerebbe che i codici materiali OMNICLASS presi in riferimento si riferiscano alla versione 2006 (OmniClass_23_2006-03-28).
Vorrei capire se:
OmniClass codes_Versione anno 2012 supera e elimina la versione 2006 o se le due versioni sono complementari tra di loro.
Grazie Smiley Happy
robert.klempau
Hello @Anonymous,
Welcome to the Autodesk Community.
the latest version of the OmniClass Construction Classification System is listed at: http://www.omniclass.org/
National Standard - 2012-05-16
I would use this version. I did not compare both.
Ask your customer wich one to use. Did he not indicate that in his BIM protocol / BIM demand?
See also: Update OmniClass Taxonomy File
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Mr.Klempau i have another question.
In the -Assembly code- there are the UNIFORMAT II code for default .
As for OmniClass codes can be set Uniformat 2010 version, replacing UNIFORMATII?
Thank you very much
Best Regards
Maria Regnani
fabiosato
Hello Maria,
On Manage tab, Additional Settings, Assembly Code, then you can browse after the file you want to use.
Fábio Sato
