Hey guys, any progress on the -24" connector bug? Steve mentions it in his blog post here: http://revitoped.blogspot.com/2013/06/conduit-connector-gone-rogue.html
This only occurs when the family parameter "Round Connector Dimension" value is set to "Use Diameter." The problem disappears when "Use Radius" is implemented. It's the only reason we haven't switched over to Use Diameter for our new families to eliminate that radius-to-diameter calculation.
Thanks!
Solved by eric_grey. Go to Solution.
I haven't found a bug logged for this, so I can't tell if a fix has been submitted. Could you add a simple family that shows the issue to this thread? I'd like to verify if the bug still exists.
Eric
Have not ran across this yet. But, we don't use anything that needs a 24" connector in the electrical field. Good to know though. Thanks for the post.
Here's a floor drain family we attempted. The radius edition you can change the pipe size on-screen by clicking the size, but the diameter edition gives you the -24" value and doesn't change the pipe size. If you use the Properties menu to change the pipe size, both function the same.
Thanks!
I'm able to reproduce the issue in the latest build. I'm going to log a new bug now to make sure we address this.
Thanks for bringing this to our attention and for the examples,
Eric
