Trouble with electrical elements model
antonio_roquette
Message 1 of 15
antonio_roquette
I had to edit an electrical element and put an usb charger, and the final looked like this
But then when I checked it in a Section, the newly usb charger just didn´t show up.
Any ideas on fixing this?
Replies (14)
Message 2 of 15
AE_RevoBIM
Check the "Family Element Visibility Settings" in the family of the USB element. Make sure its set to visible in section, or check if any of those settings are turned off. (Image attached)
Also check if the element is set to "Visible" in the properties.
Does it show in a 3D view within the model?
Message 3 of 15
antonio_roquette
Yes, it is all turned on, but I just checked it in the 3D model, and it looks like this
I have no clue why, since it is all correct when I edit the family
Message 4 of 15
iainsavage
Upload the family please
Message 5 of 15
AE_RevoBIM
Is the USB element a nested family? Can you go into that and check its Family Element Visibility Settings then reload into host family.
Something else to check, in the host model, goto a 3D or section where you can see the USB element and set the "Preview Visibility On" on the bottom left (See image). This previews the family settings. If it disappears then you will be able to troubleshoot inside the family editor
Message 6 of 15
iainsavage
Upload the family for examination, it will save a lot of back-and-forth guessing.
Message 7 of 15
antonio_roquette
Here is the family, I think the USB is not part of the host
Message 8 of 15
antonio_roquette
I now think it is a problem within the family itself, rather than a visibility one
Message 9 of 15
iainsavage
This is what I see in section in Fine detail mode
3D in Fine detail:
Message 10 of 15
antonio_roquette
Yes, but when I see it in a section, or in 3D in project, inside a room for example, it seems like the USB is not connected to the electrical host. Try to put this family inside a project and check it
Message 11 of 15
iainsavage
Here is your USB in your screenshot???:
It looks like the nested family is not constrained properly to move with the main family.
Message 12 of 15
iainsavage
You need to add another reference plane, lock the USB sub-family to that plane and then give it an offset dimension from the plane which is controlled by the Alturo do Ponto parameter
Message 13 of 15
antonio_roquette
I don´t get it. When I try to edit the family, it is already "fixed"
But it is still out of place
Message 14 of 15
fabiosato
The USB module was not inserted using the proper reference plane, which should be "baixo".
The family below is ok now.
Fábio Sato
Message 15 of 15
antonio_roquette
Thank you!
