Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
tip for creating plan regions on ceiling with variable height
5 REPLIES 5
ROSIE_SG
249 Views, 5 Replies
I have a lot of pipes in the ceiling
the problems is that the height of the ceiling change so i need to create a lot plan regions.
there is any faster to make plan regions without using sections all the time to check the height in the specific area?
5 REPLIES 5
iainsavage
in reply to: ROSIE_SG
Is it a floor plan or a reflected ceiling plan?
ROSIE_SG
in reply to: iainsavage
floor plan
but i can use ceiling plan if it will help
iainsavage
Is it the ceiling which changes heights or is it the soffit of the floor/roof above which changes?
Maybe post a screenshot of the section through the problem area?
ROSIE_SG
i make a section in a place which you can see the difference of the ceiling height.
iainsavage
If your plan view discipline is Mechanical or Plumbing I don't understand why you can't just set the top plane to the highest level - the ceiling/floor will be wireframe  and won't interfere with the visibility of the pipes. You don't even need plan regions, just adjust the view range:
Forma Design Contest
