And by the way, if you follow the article and create your own line you will see that in point 17 it suggests to get a calculated value for the array. I have tried that, and it seems to work, as per the screenshot shown on the article in point 17, but the moment I hit OK/Apply I get an error about the Array value being that of the type and using an instance value (length) to calculate it and that this is not allowed. Anyone can shed some light on how to overcome this? It would be nice, as you can then set the distance between the text values, independently of the line's length.
Jose
Update: I got this part sorted. All I had to do is to create the Array parameter as an instance parameter rather than type.
