Text parameter to turn on visibility parameter
Paul-s
Paul-s
I have a family that has a label parameter name "No of Wires" and is tied to a visibility parameter called "Label Visibility". There will be some instances
of famility that this visibility will be turn off.
Is there a way (formula) that can turn on the visibilty of "Label Visibility" if a value in "No of wires" is enter. I'm trying to save an extra step.
text name parameter->No of Wires
visibility parameter->Label Visibility
In column Formula area inside Label Visibility enter: No of Wires > 0.
Hope this helps.
Best regards, Branimir
Paul-s
Branimir,
Thank you. But it did not work. "No of Wires" is a  "Tex" parameter.
nathan.chapman
Paul-
You will have to change the parameter to an integer or number.  Text parameters cant currently drive formulas.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Paul-s
Thanks Nathan...I guess I just have to check the visibility box. Thank you again.
