Two System Classifications? How to fix it?
GTisRuleX
GTisRuleX
So I have a drain that was classified as "Hydronic Supply" when piping was hooked up and it wasn't noticed.  I edited the family, changed the connector to "Sanitary" and reloaded to the project without overwriting parameter data, now the system classification shows "Sanitary; Hydronic Supply"
If water squirts out of a drain, there's bigger problems, so getting this set to Sanitary would be the only correct setting.  I've tried cutting/pasting the fittings back as well.
GTisRuleX
Fixture had two connectors. The Trap primer connection was also set to Hydronic.
andrea.kikuchi
Autodesk Support
Autodesk Support
Hi there @GTisRuleX
This was an interesting case...did fixing the extra connector solve the problem for you?
Thanks!
Andrea K
Technical Support Specialist
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
GTisRuleX
Yes! I'm sort of kicking myself for missing the trap primer connection and spending so much time trying to figure it out when it was pretty obvious in the end!
andrea.kikuchi
Autodesk Support
Autodesk Support
Don't feel bad, this one would have stumped me too! Glad it worked out in the end for you. 🙂
Andrea K
