switch family
switch family
yoosafshajeeb
switch family
yoosafshajeeb
Hello friends,
I want to maintain the distance by 10 mm between two switch board .When I try to reduce the distance by 10 mm , the top view is overlapping . Drawing scale is 1:100 .Any option is there ? Pls.find attached pic.
Thank you
Add an instance dimension parameter in the family to control the location of the switch symbol.
s.borello
I agree with @ToanDN... add an annotation offset param to the family so you can nudge the symbol to the proper location.  This will not effect the placement of the model family.  Another option would be to create a call-out at an appropriate scale so your view is displayed the way you want it.
