Show only
Search instead for
Revit MEP is not meant to nor is it capable of performing the full tasks that Revit Architecture or Revit Structure are meant to do. It sounds like you might benefit more from the use of Revit Structure.
Corey D. ────────────────────────────────────────────────────────────────────── ⁞|⁞ Please use .Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you!
