Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Standard Mechanical Piping Library
2 REPLIES 2
zepeng.zhao
213 Views, 2 Replies
Hi all,
Is there any standard piping system family library resource available, I experienced almost all the project almost all of them are struggling with the standard family library for fitting valve flange etc that are match with ASMI or DN code. the question is do we have the standard library for piping system like plant3d.
2 REPLIES 2
Lockey7
in reply to: zepeng.zhao
Hi there,
There should be a piping template included in the standard library of templates you get with Revit.  The one I use in the UK is the 'UK Pipe Template', where there are a number of pipe routing preferences already set up.  They can be transferred into other projects.  I presume there is something equivalent set up for other regional standards also.  I hope this is of some use!  Cheers.
Simon Locke
Principle Consultant - Symetri UK
zepeng.zhao
in reply to: Lockey7
Thanks for sharing @Lockey7 , it's really helpful.
Forma Design Contest
