Spinning wheel of death
Has anyone been getting the spinning wheel of death? Only happens in Revit 2019. After I open a file, it goes into busy mode (hourglass) for 15-30 seconds, stops thinking long enough to let you move, then starts thinking again. I do NOT have this issue in Revit 2020. Any tips or suggestions?
fabiosato
Do you have site designer installed? If yes, try to install it.
Fábio Sato
That was the solution! Thanks fabiosato. it needed updated. Now it works just fine. Do you know why this happens and what site designer does to fix it?
fabiosato
It is a known bug, I also had this problem before, if you need to use it, install, model, and then uninstall.
Fábio Sato
