some product failed to install . result 2
Screenshot (1).pngsir/madam
               i tried to install revit 2015 and autocad 2013 many time . but there was same problem repeat everytime. i format my harddisk  and reboot my os 7 ultimate 64 bit with window 8.1 pro and w7 ult. itself  many time but got same proplem . i tried the solution give by autodesk on same problem but result 1603   did not work at all. i uninstall microsoft c++ 2008 from control panel but still no work. now i tired to keep solving my error 2 .now i am asking for help please help me. installation log is
2016/7/30:10:51:43 Tanveer hassan TANVEER === Setup started on TANVEER by Tanveer hassan ===
2016/7/30:10:51:43 Tanveer hassan TANVEER Launch
2016/7/30:10:51:53 Tanveer hassan TANVEER === Setup ended ===
2016/7/30:10:51:46 Tanveer hassan TANVEER === Setup started on TANVEER by Tanveer hassan ===
2016/7/30:10:51:46 Tanveer hassan TANVEER Launch
2016/7/30:10:51:52 Tanveer hassan TANVEER PageOpen LaunchDialog
2016/7/30:10:51:54 Tanveer hassan TANVEER PageOpen LicenseDialog
2016/7/30:10:51:57 Tanveer hassan TANVEER PageOpen ProductInfoDialog
2016/7/30:10:52:02 Tanveer hassan TANVEER PageOpen ProductSelectionDialog2
2016/7/30:10:52:20 Tanveer hassan TANVEER PageOpen FullProgressDialog
2016/7/30:10:52:20 Tanveer hassan TANVEER Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\Autocadd 2013 64 bit\Autocadd 2013 64 bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2016/7/30:10:52:20 Tanveer hassan TANVEER Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=2
2016/7/30:10:52:22 Tanveer hassan TANVEER PageOpen InstallCompleteDialog
2016/7/30:10:53:05 Tanveer hassan TANVEER === Setup ended ===
2016/7/30:11:04:04 Tanveer hassan TANVEER === Setup started on TANVEER by Tanveer hassan ===
2016/7/30:11:04:04 Tanveer hassan TANVEER Launch
2016/7/30:11:04:28 Tanveer hassan TANVEER === Setup ended ===
2016/7/30:11:04:11 Tanveer hassan TANVEER === Setup started on TANVEER by Tanveer hassan ===
2016/7/30:11:04:11 Tanveer hassan TANVEER Launch
2016/7/30:11:04:28 Tanveer hassan TANVEER PageOpen LaunchDialog
2016/7/30:11:04:32 Tanveer hassan TANVEER PageOpen LicenseDialog
2016/7/30:11:04:35 Tanveer hassan TANVEER PageOpen ProductInfoDialog
2016/7/30:11:04:45 Tanveer hassan TANVEER PageOpen ProductSelectionDialog2
2016/7/30:11:04:49 Tanveer hassan TANVEER PageOpen FullProgressDialog
2016/7/30:11:04:49 Tanveer hassan TANVEER Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): D:\Autocadd 2013 64 bit\Autocadd 2013 64 bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2016/7/30:11:04:49 Tanveer hassan TANVEER Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=2
please solved it out plz plz plz
I have same problem for days.
I successfully install AutoCad 2016 Mechanical and Inventor 2016, but Revit 2014 or 2016 i cant.
Also cant install same Updates.
I solved my problem.
I successfully installed Revit 2016
in my case I had to delete all autodesk material library 2016
as you can see image in attachment shows that is already installed and because of this installation is faild.everything in this picture must be clean.
second, must modify setup.ini file like here
https://knowledge.autodesk.com/community/screencast/cb699690-d649-43ee-a29a-a8d58d42e1db
